2007-08-04 07:56 PM
2007-08-10 10:57 AM
2007-08-10 07:17 PM
rwallis wrote:
Mark, the really great thing about Apple using Intel chips, and their choice to release windows drivers for Apple machines, is that you don't have to put up with slow and buggy (and expensive) emulators to run Windows software on an Apple machine.
What you do need to own (or buy) is a legitimate copy of Windows - XP/ Vista etc.
Then there is the choice of how to use it:
1. Apple provides "boot camp". Once this is installed you can install your copy of Windows, and then, whenever you start your Apple you can choose between going into the Mac OS X or (your copy) of Windows.
Good=Boot camp is free, and all the resources of your PC are dedicated to the OS running at that time.
Bad= Cannot run at the same time as Mac OS X (must restart machine to switch between OSes)
2. Spend more on 'Parallels' or 'Fusion'. These software(s) allow you to run both OSes concurrently! In your MacOS X dock you can have an application running natively in windows!
Good=No restart delays switching between OSes. Can stay in the MacOSX environment the whole time!
Bad= Costs more. When both OSes are running it uses more resources. The new core 2 chips are built for such concurrency in mind (virtualisation if you want the tech term) but there is always a cost in performance.
Good luck
2007-08-10 11:16 PM
Mark wrote:Which 20.1" laptop do you mean? From what I've seen the 20.1" screens have the same resolution as my old MacBook Pro (1680x1050) so what's the point? To sit farther from your laptop? The new Macs have an option for an even higher res. Personally I would go for the higher resolution in the smaller package and add a 23" or 30" display when I really want room play.
The only issue that has me torn now is that I had my heart (and eyes) set on a 20.1 inch display. Do you ave any insider (or outsider) information on the possibility of Mac releasing a 20.1 MacBook? I would be willing to wait if this were the case.
2007-08-11 03:27 AM
2007-08-13 08:38 PM
Mark wrote:...but without more pixels you're just enlarging the same image. It seems easier to carry a spare pair of glasses than to lug around a bigger laptop.
[Which 20.1" laptop do you mean?
There are several on the market. Hypersonic, HP HDX andVoodoo, Seger, etc. I want it for more real estate. Simply increasing resolution on a small screen always makes graphics hard to read for me. And I want to remain mobile with a 20.1" Laptop.
2007-08-13 08:52 PM
2007-08-20 12:30 AM
2007-08-20 06:14 PM
2007-08-22 07:45 PM
2007-09-18 01:26 AM
