A slab will split but a roof won't...
hi
I can draw a simple slab and split it.
I have a simple square hipped roof that I want to convert to gable end. why doesn't split work on the roof?
any ideas welcome.
TIA
Nicholas
Groups again, most likely. 'Reshaping' (split, adjust, stretch) grouped elements is generally not allowed; you need to suspend groups. Also, be advised that a 'simple' hipped roof isn't actually simple, it has four separate roof elements.
James Murray
Archicad 27 • Rill Architects • macOS • OnLand.info
probably saved me at least a couple of hours figuring out and getting annoyed...
thanks James.
