2011-08-23 07:04 AM
2011-08-23 08:20 AM
2011-08-23 04:14 PM
2011-08-23 06:56 PM
drh64 wrote:The main change is the way the guidelines are activated (the orange dot). Everything else seems to work pretty much as always for me. Perhaps there was a change in your work environment?
The simple things like drawing a line at 45 degrees from a starting point. What happened to that???? Drawing a line parallel with another line???
2011-08-23 07:06 PM
2011-08-24 04:49 AM
drh64 wrote:Make sure in your Work Environment under Guide Lines you have the incremental angle set to 45°.
2011-08-24 04:55 AM
drh64 wrote:Start to draw your line (pick first point).
2011-08-24 05:02 AM
2011-08-24 05:06 AM
2011-08-24 09:14 AM
