AC 16 Quick selection tool in 3d window
Working in 16,
Quick Selection tool (magnet icon) doesn't work in 3d window like version 15, 14, 13, 12,...
Space bar activates it in 2d.
What am I missing?
Clicking on a surface in 3d to select an object, rather than just the edge or node. How is it done in 16?
Thanks.
23 REPLIES 23
Unfortunately opening an existing AC15 file and applying the Standard AC15 profile and defaults to the project, then saving and importing into AC16 does not resolve the issue. The problem seems to be embedded elsewhere...
Further suggestions welcome.
Cheers
No amount of changes seem to help.
Tried reinstalling AC16 without importing settings from AC15 to see if that helped. But no difference.
Also ran the consolidation of libraries to see if that helped, no difference.
I have tried turning 3D anti aliasing on and off to no avail.
Pressing the space bar tries to change the state of the "magnet" button but it remains greyed out. It only becomes live once you select an object, which is completely useless.
I've opened the "problem" project on another machine running AC16 in the office and the problem remains.
Other office projects randomly seem to either work or have the same problem. Truly bizarre.
I cannot for the life of me find a setting in the AC15 project that would cause the object selection to malfunction once its imported into 16? It makes absolutely no sense.
Eric Bobrow
Kirby -
I'm going to ask you something that may be totally obvious, but is worth checking. The selection arrow in AC16 now has two states, the traditional one that selects elements, and a new one that is used to select morph sub-elements. The traditional state shows the cursor arrow in black, the new option has the arrow in white. Please check to make sure that the arrow is set to the traditional black (whole element selection) since the magnet may not be functional for the sub-element state.
Eric
Katalin Takacs
Thank you all for the remarks.
In ArchiCAD 16 the Quick Selection is greyed out in 3D Wireframe mode by design. Changing between the 3D wireframe and shading modes might cause the issue you observed.
As a workaround, please try the followings:
1. Open View/3D View Options/3D Window Settings
2. Switch from OpenGL to Internal Engine mode
3. Set Shaded Mode from Raster to the default Analytic Mode and click OK
4. Open 3D Window Settings again and switch back to OpenGL engine
After clicking OK, the Quick Selection option should be usable again.
Please let me know if you need further help.
Katalin Takacs
Thanx All for ur replies.....
and Katalin Takacs....u really helped....it solved the problem.....
I too have had this problem, I did not realize the problem was stemming from importing from V15, but the solution offered by Katalin works for me. Unfortunately, I will have to do all my 3d editing in Shading mode? I don't really like shade mode, I like hidden line. Why would the magnet not work in hidden line mode? Is this a glitch in the program that will be resolved?
kikoskiki
Hi everybody;
I have the same annoying problem. But I don't know if it is a bug or a change, since I read this in archicadwiki:
Quick Selection is Disabled in Wireframe Mode
In Wireframe and Hidden Line 3D display modes the Quick Selection (Magnet icon) is no longer available by design.
This is the link:
http://archicadwiki.com/ArchiCAD16ChangesGuide#Change_in_Default_Installation_-_Work_Environment_mig...
Thank you for any suggestions
AC18 - Intel Core i7 3740QM @ 2.70GHz 16GB Ram. Nvidia Quadro K1000M. Windows 7 Ultimate 64bit
Disabled in wire frame I can understand as it is just a frame view - no surfaces.
But in hidden line it could be considered as a bug depending on how you look at it.
You can't see the colour of the surfaces but they are still there as they hide the lines.
I would consider it as a bug that we can't use quick select now in hidden line mode.
David Maudlin
Agreed. Hidden Line Mode is the best way to check the accuracy of the model and know what it will look like in section/elevation windows (surfaces in plane, material's match between planes), so the ability to select by surface in Hidden Line Mode should be brought back.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
I have the bug too. I have a iMac with a radeon card, and sometime I can´t select like in previous versions...
