AC 18 Copy Paste
Hum,
Does anyone have this Issue ? I can't Ctrl+C Ctrl+V stuff (object, wall, slab..) between 2 openned Archicad 18.
It lagg, than freeze The "paste in" Archicad. Have to close it and reoppen to Work. And the Video card Fan gets crazy.
I use this all the time, Because of a library of ready made room.
Win 7, AC18 Fr, Nvida Card 770 GTX.
In fact, I can't have two archicad Openned at the same time.
Try on my laptop, same thing.
Ask a Friend about is archicad, Same Thing.
Does anyone else have this issue ?
Could you please open 2 archicad 18 ? See if you can work on both.
More information, If I wait long enough (btw 10-20min) the second archicad become usable. but before that Cpu is running full, at least one core.
Eduardo Rolon
Read here:
http://archicad-talk.graphisoft.com/viewtopic.php?t=47032&postdays=0&postorder=asc&&start=10
This could be the same problem.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
You save my week!
Thank you so much.
I going to print this and pin it to the wall.
