2016-01-06 07:00 PM - last edited on 2023-05-25 04:46 PM by Rubia Torres
2016-01-06 10:47 PM
2016-01-06 11:19 PM
mwadlund wrote:What version of ArchiCAD are you using? It might be related to your operating system. ?
Hi - I just upgraded from 16 to 19 - definitely seeing an improvement in speed. One issue, I'm having problems with "show on stories" command working with floors and stairs. For example, I'd like a stair to be shown on Home Story only, but the "Show on stories" will not change in the Floor Plan Display. Suggests for troubleshooting?
Thx
2016-01-07 12:14 AM
Steve wrote:mwadlund wrote:What version of ArchiCAD are you using? It might be related to your operating system. ?
Thx
It works for me using Windows 10 Pro.
If I edit the stair to show on story below, story above, home story only... it works.
Did you check to see that your story levels are set the way you want them ? Cut Plane ?
2016-01-07 01:29 AM
arqrivas wrote:
Are you opening a project that came from AC 16 or you are doing a new one?
2016-01-07 02:28 PM
2016-01-08 06:05 PM
laszlonagy wrote:
Updating to the latest ARCHICAD 19 build will hopefully solve your problem:
http://helpcenter.graphisoft.com/technotes/operating-systems/mac-os-x-10-11-el-capitan-beta/#Can8217...
This is one of the examples of why is it advisable to be always updated to the latest build as it contains numerous bug fixes.
2016-01-08 06:43 PM
2016-01-09 03:02 PM
mwadlund wrote:In addition to Laszlo's advice, there is a Check for Updates... command under the Help menu if you want to check immediately.
I don't get regular notification that updates are available - how do you get these notifications?
2017-05-25 06:49 PM
