AC-24 : Roof Tool not cutting wall the same as Slabs
tsturm
Why Does the Sloped Incline Tool not cut the walls the same way a Slab Tool does?
Here is what looks like a slab interesting the exterior wall. Yet this is a sloped incline. "roof". Why does the wall not get cut the same way a slab would? This composite is set for slabs as well and they are cutting the same exterior wall composite just fine.
Terrence Sturm, Architect
_______________
MBP OSX 10.15.4 Quad Core Intel i7 2.2hz
AC 17 build 5019
AC 22 build 7000
AC 23 build
AC 24 build 5000
4 REPLIES 4
tsturm
Here is the Slab cutting the wall.
_______________
AC 17 build 5019
AC 22 build 7000
AC 23 build
AC 24 build 5000
runxel
Hero
For roofs there is no automatic way of priority based intersection. You can do it manually, tho.
tsturm
I presume by a SEO function they can be made to look clean cutting.
_______________
AC 17 build 5019
AC 22 build 7000
AC 23 build
AC 24 build 5000
runxel
Hero
No SEO needed.
Just use the option to "Merge elements".
