I know I've seen some discussion of this but I can't seem to find it. (I haven't paid that much attention to the issue since I rarely us the included libraries.)
The AC 8.1 doors in the US library are not working when placed in a wall in which SEOs have been used. The symptom is that doors which are supposed to appear paneled are modeling as solid. They work properly in the settings dialog preview.
I am using the US library "ArchiCAD Library 81.pla" dated 10 October 2003. Is there a more recent one that fixes the problem?
For anyone who is interested, I have found the problem in the GDL code for the door (D1 81.gsm in this case). It is in the 3D script (naturally) as follows:
!!! D1.gsm USA!!!
IF gs_detlevel_3D_m=0 THEN END
PEN gs_frame_pen
RESOL res
IF gs_shadow=0 THEN SHADOW OFF
IF gs_shadow=1 THEN SHADOW ON
IF GLOB_CONTEXT>20 THEN gs_detlevel_3D_m=1
The problem code (in red) is testing for new values of the GLOB_CONTEXT variable. In this case the culprit seems to be:
43 - generating as an operator from a 3D view
The line is resetting the 3D detail level to 1 (simple), thus the solid door.
I have fixed this for now for my own purposes but if there is a library update I would like to install it. I might even have it somewhere lost among all the versions I have on my laptop and server. I just want to know if it exists before I start searching.
