2003-11-17
07:03 PM
2023-05-25
06:06 PM
Rubia Torres
2003-11-18 03:27 AM
2003-11-18 05:35 AM
2003-11-18 01:25 PM
Karl wrote:... and screen shot ...
I tested the windows and doors a little bit in 8.1 and didn't see this. Could you guys give an example - with a specific library part name?
2003-11-18 06:11 PM
2003-11-18 06:31 PM
TDabney wrote:FYI - This is a quote from the "read me first" that came with the upgrade.
Hi -
I just received my copy of 8.1 and am having some issues w/windows and doors. I'm working in a project started in 8.0v3...
Tom
2003-11-18 07:02 PM
Richard wrote:I suspected this was some sort of 8.0/8.1 conflict but it seems to run a little deeper. I've been trying different things like: deleting and replacing parts that aren't displaying porperly, deleting entire walls and starting from scratch replacing the windows and doors w/just 8.1 parts etc... I've had mixed results still. One wall, I totally replaced and popped in a new door - worked fine - until I did a solid element op. on it to trim to a roof above which made the door go to a solid slab. So I un-did the solid element op. and did just a trim to roof - which worked fine. At the moment things seem inconsistent - I'm sure there's a rhyme to the reason, but I don't have the time to keep messing w/all the different combos to figure it out.
2003-11-18 07:23 PM
Richard wrote:TDabney wrote:Warning!
Hi -
Tom
Libraries
Object libraries shipped with or created in ArchiCAD 8.1 will not work with ArchiCAD 7.0 or earlier andwill be partly compatible with ArchiCAD 8.
2003-11-19 05:45 PM
2003-11-19 07:08 PM
gkmethy wrote:gergely,
More to library handling in ArchiACD 8 and 8.1: please read article by Ransom Ratcliff on ArchiGuide:
http://www.graphisoft.com/support/archicad/archiguide/guid.html
