UPDATE;
Ran the beast around the track a few times and no oil leaks yet.
However; with no real info, all this dialog does it scare the you know what out of me for what?
Will it go puff in the night?
Is it a fatal flaw or minor whatever?
Will it have printing problems at deadline?
In other words, what level of risk is file in.
A risk status bar might be helpful.
I think telling the user how the error is fixed may become too technical.
The user can look at the affected elements so he see if they look and act like they used to. Maybe a Slab was degenerated and was modified by the program. Now it does not look like you drafted it so you may want to delete it and redo it. Looking at the element helps you decide whether there is any action needed on your part.
If you save it at this stage under a new name then you will have the version prior to and after the problem occured. So any element will probably be available in either of these versions in case elements were deleted.
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac29
laszlonagy wrote: I think telling the user how the error is fixed may become too technical.......
Hi Laszlo
Thanks for the reply.
However, I did not mean to imply "how" it was fixed, just what was fixed, as it did not do what it said it would with the little button to the right.
Still feel it should give a status of relative risk to file right there or
at least a link that worked.
