AC for mac
Roopa A
Cant we open AC 21 side by side in mac machine?
If yes, how to open.
Thank you.
Roopa A S
Eduardo Rolon
If you are referring to Launching 2 (or more) AC sessions side by side the answer is yes. After opening the first one select Open or New and on the window click on the option for "Launch a new instance of ARCHICAD"
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
Ole
There is a setting in "Work environment". See screenshot below (I don't have an English version of AC installed, but you should be able to figure it out).
If checked, a new instance of AC is opened if you double-click a file in Finder for example.
ARCHICAD since 4.55 | macOS current | AC 26 current
