2006-07-20 09:05 AM - last edited on 2023-05-25 05:01 PM by Rubia Torres
2006-07-20 11:04 AM
2006-07-20 06:20 PM
2006-07-20 11:06 PM
Benjamin wrote:because you have a parameter error in the 2D script - the model part of the stair is working just fine, but it's symbol is running into errors. try looking through the stair settings that relate directly to its 2D representation . . .
If the stair folder is not loaded, why it would appear normal in 3D and Section view but not in plan view?
2006-07-21 02:04 AM
2006-07-21 12:30 PM
2006-07-21 03:13 PM
uisanata wrote:Do you have two copies in the same place? Coincident elements cancel in 3D, leaving a void.
i have the same problem but it looks a bit different. the stair is disappearing from sections, like all lines are going transparent. when i revert to plan views it's there. i have to 'guess click' it, go to setting dialog, edit the stair (changing nothing) and it comes back.
it happened during the plotting process, too.
2006-07-25 08:59 AM
2006-08-30 08:06 AM
Benjamin wrote:Same problem here. I would say it is a Mactel bug.
I can only see the stairs in plan view as a black dot. It shows normal in section, 3d views. The problem persists when I made a fresh copy of the same stairs.
