AC11 Crashing
Red
Just this morning every time I try to go into wall, object, door window, etc settings AC11 is crashing on me.
I've got the latest update installed and I'm currently downloading the latest Lib.
Anyone else here had this problem?
Thanks,
Red
i7 8700k
ROG Strix Z390-E MoBo
64gb RAM
EVGA GeForce GTX 2080
_______________________
http://www.facebook.com/flatcreekdesignstn
http://www.sraarchitects.biz
AC6 to Current
8 REPLIES 8
Red
*** Correction ***
Either it will not open the settings box or it will eventually crash after several attempts.
Thanks,
Red
i7 8700k
64gb RAM
AC6 to Current
Red
Well with a windows update and a couple reboots later everything is fine.
Thanks,
Red
i7 8700k
64gb RAM
AC6 to Current
piton
I've found a common thing in my ArchiCAD crashes:
It happens when i try to move some objects (simple objects, simple selection), and some dimensioning text was also selected, without the dimension line itself (they fell into the selection bounding box).
With very few selected objects everything is ok, but above about 10 things AC crashes (detailed workflow: selection - CTRL-D - click for vector 1st point - click for vector 2nd point - hour-glass mouse pointer for 1 sec. - bugreporter)
My Windows and AC11 is freshly reinstalled with all updates.
Anyone else has this probem? If so, let's flood Graphisoft with the bug reports. šŸ™‚
piton
Here is a file to recreate the crash.
no extra libraries.
one simple line.
one simple dimension.
the middle dimension point connects to no elements (squared point when entered).
select the line and one of the dimension numbers, move it and crash.
"works" on other computers in the office.
Please fix it ASAP.
Pete
Are you using Vista or XP?
We had similar issues on Vista with AC11. The problem went away after updating to the latest Microsoft DirectX version and also updating the video card driver.
Pete Read
ArchiCAD 12; Artlantis Studio 2
MacBook Pro 2.4 Core2Duo, 2GB, OSX(10.5) and XPpro(SP3)
piton
my config is: Windows XP SP2, Pentium 4 3Ghz, 2 GB ram, ATI Radeon 9600 PRO AGP 128MB, Archicad 11 1040 HUN, Phoenix AwardBIOS v6.00PG, DirectX 9.0c.
piton
updating the video driver didn't help.
Greg Kmethy
piton,
Your description gave us the clue to the reproduction of this crash. (moving dimension text, but not the dimension line) This helps a lot in fixing this bug. Thank for posting.
Gergely Kmethy
VP, Customer Success, Graphisoft
