‎2008-01-25
08:18 PM
‎2023-05-25
05:11 PM
Rubia Torres
‎2008-01-25 11:09 PM
‎2008-01-26 08:19 AM
Landry wrote:Hi Landry,
Is your Vectorial Hatching turned on under
View - On-screen View Options - Vectorial Hatching
‎2008-01-26 10:52 AM
‎2008-01-26 12:09 PM
Brett wrote:Hi Brett,
I have had this happen intermittently with AC 11 also. Hadn't noticed what had caused it. Just tried playing Windows Media Player while AC was open (and no split screen). Closed Player and went back to AC and the split screen has appeared. So can confirm the process of it appearing. As you say a restart fixes it. I will log it with GS NZ and suggest you do the same with your reseller.
‎2008-01-26 06:16 PM
Brett wrote:Hello again, Brett,
‎2008-01-27 06:30 PM
‎2008-01-27 07:28 PM
adytc wrote:This is not ArchiCAD, but something with your display driver. Make sure you have the most current driver. Even if you do, if you have installed any Windows Updates, I've found that the updates screw up the driver at times, and it has to be reinstalled. That's Microsoft's fault, not Graphisoft's. Finally, make sure Vertical Synch is off:
1. If I select an element in the floor plan and zoom in or out, the Info Box behaves like it's refreshing (it blinks) - this happens only if I have selected something - and it becomes tiresome after a few hours of work.
2. If I want to edit some element's floor plan and section display mode using the info box, the properties window (see attached image) disappears after each modification I make (this wasn't happening in AC10), which can be very frustrating, as I have to click on "Floor Plan & Section Display" button after each step.This flyout from the Info box stays open for me in 10 and 11. Do you have a non-standard mouse driver installed by any chance? I don't see anything in the Work Environment that should affect this behavior.
‎2008-01-27 07:49 PM
Karl wrote:I didn't know that about Windows updates. Thank you for this info. I'll reinstall the drivers and see what happens. (vertical sync is turned off)
I've found that the updates screw up the driver at times, and it has to be reinstalled. That's Microsoft's fault, not Graphisoft's. Finally, make sure Vertical Synch is off.
Karl wrote:I don't have a mouse driver installed. At a second look, it seems that the flyout menu problem applies only to walls, windows and doors. For the rest of elements, it seems that the menu stays on screen until I click somewhere on plan.
‎2008-01-27 08:11 PM
Karl wrote:I've reinstalled the drivers, turned off Vertical Sync, but with no result.
