AC11 Display Bug
Hello everybody,
I've recently started working on Archicad 11 (1114) and something very frustrating happened; I've created a simple rectangular mesh, draw some lines and when zooming in or out, the display becomes fragmented (see the attached image). I've erased all and even with a new empty scene, when zooming, I come against the same problem (this time visible due to grid display). Is this a hardware problem? (my graphic card is GeForce 7300 GT (256 Mb) with the latest drivers installed)
I have to mention that in AC 10 I've never encountered this kind of problem.
(I don't know if this is the right section to post this, so I'll post it again in "Hardware" section; sorry for any inconvenience)
Thank you in advance.
Adrian Tudoreanu
14 Replies 14
Sorry none of my ideas helped. Contact tech support?
Anybody else have the same graphics card as Adrian?
That's ok. I really appreciate your support.
Contacting technical support will be the next step. I'll make a post here if I find out something useful.
Thank you again.
Cheers.
Adrian Tudoreanu
I get the split image on scroll as well. Happens randomly as much as I can tell. More likely to happen with trace reference on. Not the way I want to work
ArchiCAD 11 build 1114 usa full
windows XPsp2
Is Vertical Synch turned off for you, Cary? Split scrolling, particularly in 3D, was the symptom I had long ago before turning VS off.
Thanks Karl. I just turned it off. If I see anything weird all report back.
windows XPsp2
