AC11 Little improvements......
Wanted to start a list of AC11 Little improvements......which are not announced:
First Selection outline now is shown in dots
Second Selection outline is shown in Dot Dash Dot
Nice, yet still short cut C for changing of the method is still not implemented, must be very hard to code it in!
Joseph
143 Replies 143
Aussie wrote:
Select the file/app/whatever in finder. Command I (info). Click on the icon then command V (will paste what is in the clipboard into the icon view).
Command X or delete to go back to the default.
I have tried this but have not had success. Does it matter what format the image file is in?
Erich
Hi Mike,
It works pretty much like it always has on a Mac. After you select the program and hit command "I" then select the icon for the program in the "Get Info" window, then command "V" to paste in the new image.
The most common error I see is folks don't select the icon image in the window that comes up.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Thanks Erich. I was trying to select the icon in the preview portion of the get info window and apparently you need to "select it" in the header of the get info window.
SeaGeoff
Ace
Here's a Mac friendly 128x128 pixel tiff I just made.
Also note that you can change the application name that appears in the dock by simply changing the name of the application in the Finder. Changing the name in the menu bar is slightly more complicated. You need to edit the info.plist file within the application package. Go find the free Pref Setter utility and use it to change the CFBundle Name key. (Save a copy of the unaltered app first.) I now have everything named ArchiCAD 11.
Regards, Geoff Briggs
I & I Design, Seattle, USA
AC7-29, M1 Mac, OS Tahoe
Graphisoft Insider's Panel, Beta Tester
Back to New Little Improvements....
I like the new command:
Transparent Fills & Zones
can be found in shortcut Work Environments.
Joseph
TomWaltz
Joseph
It's also on the Trace & Reference Palette.
Tom Waltz
Rafal SLEK
Transparent Fills & Zones works only when Trace is activated.
Another simple but useful one - new User Interface for Door Dimension Marker.
Best
Rafał
//Archicad since 4.1 version
//MacBook Pro Tahoe/Retina 2019/2.4 GHz/Intel Core i9/32GB RAM/Radeon Pro 5500M 4GB/
//MSI AMD Ryzen AI 9/2.5GHz/32GB/Nvidia RTX 5070 Ti/Windows 11 Pro
//ArchiCAD Collaborate
Stress Co_
In Drawing Manger.... the Primary and Secondary sorting order indicators have been improved. You can see them now and they indicate ascending or descending order (which don't have to match).
Also.......
Rod wrote:
RichYoung wrote:
I cannot seem to be able to create a section that staggers/.........is this no longer available in A10?
That's correct Rich. Something that really annoyed the hell.
After placement you then have to edit!!
Get 11 it is fixed, and allows you to place segmented sect/elev markers directly.
Marc Corney, Architect
Red Canoe Architecture, P. A.
There's a slick new library part called "Material Legend 11" under Graphic Symbols 11>Drawing Symbols 11.
Richard
AC26 (since AC6.0), Win10
The measurement tool now shows the cumulative length and area if you keep clicking as well as the individual segment lengths.
