‎2007-06-20 12:34 AM
‎2007-07-24 04:09 PM
gkmethy wrote:Oh, I love it. The ADM file caused me all kinds of problems.TomWaltz wrote:The information stored in the .ADM file is now included in the .PLP file. It was a constant source of error that the ADM and the PLP file could fall out of sync (either when reverting to a backup, or caused by I/O problems), so it is simpler and more robust not to have ADM files. It is a baby-step, but an important one, IMHO.
Has anyone else noticed that AC11 Teamwork files no longer have .ADM files?
‎2007-07-24 05:50 PM
borgo1971 wrote:There are 2 ways to handle this. GS did this in full knowledge, but I don't know why. Here is their reply in beta testing...
and second little worsening (always on OS X): with AC11 seems I can't *plot* to my HP DJ500 so I did until AC10, using direct TCP/IP connection, but I must use system driver (also to plot), but... HP DJ 500 driver isn't selectable in the driver list (seems I can select only Postscript driver). So the only way I found is to use Print instant as Plot, that is much slower
‎2007-07-24 08:50 PM
gkmethy wrote:Hi Greg, do you also plan on eliminating the pln.lck file? Seems like another arcane bit of rubbish who's function should be built in.
‎2007-07-24 09:04 PM
Geoff wrote:I almost like it... it tells you before you try whether someone is signing in or not (so you don't bother right away)gkmethy wrote:Hi Greg, do you also plan on eliminating the pln.lck file? Seems like another arcane bit of rubbish who's function should be built in.
‎2007-07-25 02:47 AM
borgo1971 wrote:You may wish to review this article explaining a change between AC10 & 11.
‎2007-07-25 03:44 AM
Unfortunately, the side-effect of the rewrite was that the plotter settings for ArchiCAD 10 are not compatible with the ArchiCAD 11 plotter drivers. Therefore, in ArchiCAD 11 you have to set up the plotter again. You can not preserve the old settings.
‎2007-07-25 09:12 AM
archicadwiki wrote:
In ArchiCAD 11 you can use any connection type that MacOSX supports.
‎2007-08-15 10:17 PM
‎2007-10-04 11:25 PM
‎2007-10-05 11:00 AM
Any connection? That's not true... if it was so I didn't have problems, I did all right. The thing I don't know, is that I must create a HP socket TCP/IP printer (that let me not select HP driver so as bonjour connection) and use this. Here you can see the two Printers I created (one Bonjour for printing trough HP driver and one TCP associated to a General Postscript Driver, only to plot from Archicad).
