AC11 & AC12, It's Minor Bug?
Speed in AC12 have been good
in a few comand problem : Drag, Rotate, mirror, Drag a Copy, Rotate a Copy, Mirror a Copy, Multiple Copy, Rotate Multiple Copy.
sometimes we copy, removes object still bringing object intended to area which in going to from origin area that is actually we don't want the object make a move, this problem also happened in AC11.
are there also other experience this thing ?
my hope GS can improve; repair for completion of comands like this, because that thing often done in work in AC.
Thanks,
9 Replies 9
Link
Yes, I've experienced this too. And sometimes I swipe over a bunch of items and only select a couple. I figured it was a video problem.
I also have other programs maximize over AC12, or maybe AC12 is minimizing. One of the two.
There's a few niggling bugs in AC12 2050 that I just can't put my finger on (yet).
Link.
Rod Jurich
Link, which version are you on, INT 2156 is my version. I thought 2050 was the RC1 or 2.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
In a few problem which I meet, sometimes I have made line or notation of line for story level at marker section but result gotten at slice picture still be straight line that is is not synchronized with story level at marker section. Some changes can happened if I to vanish marker section and recreates but this a more regular happened if I to make picture in a work of new design
sometimes can be synchronize and can not
Dimension grid tool also sometimes not seen at even a slice in rebuilt and sometimes also emerged by itself so that if I make in manual hence in a moment I am rebuilt there will be measure heaping
If this problem myself experiencing of course what becoming insuffiency at my AC system??
but if was also experiences it the same thing might not better be minor this becomes main priority in repair of release hereinafter by GS and Team
Forgiveness if there is writing mistake of my english
Thanks,
Very nice model/drawings.
I noticed the same thing with my dashed story level lines appearing solid in 12...and have not yet taken the time to figure out why...if it is me or a bug...
Thanks Karl,
thank you for its(the praise for spirit [of] better.
Line at level story doesn't crumple or possibly happened double line, this thing my am natural when usage in AC11 and now I have been upgrading to version AC12 and tries opens file done the in AC12 that way doesn't experience change at the time I to do process rebuilt
I have investigated does happened heaping of line or possible of I am wrong in determining level at menu section simply no, I still looking for situation where the mistake so that why happened difference of form and line colour between its the cuttings and cutting menu sub
For this problem I have not met it at AC12 and hopefully that [shall] no longer happened, because I am new put into use version AC12 seven last day after I has just received software consignment opening from distributor in Jakarta.
Greeting,
Link
I'm on INT 2050 from beta, never received a CD and can't seem to update it online. How did you get 2156?
Link.
Rod Jurich
Link wrote:
/.. How did you get 2156?
From beta site, but that is now closed for d'loading.
You should have recieved mail from GS regarding your copy.
Suggest you contact "The Red Castle"
Rod Jurich
Link
Thanks mate. Ben had actually filled me in. I should be good to go tomorrow.
Link.
Djordje
... and it was closed since July 17th. I presume the download from the main site works now - the same as Student and Trial?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
