AC14 "locked" objects - SOLVED
Hi!
I'm having problems with some of the furniture in the floor plans. They seemed to be locked (attachment) and I can't move/change/delete them whatever I do. If I open Object tool setting, the OK button is grayed out...
This happened completely out of the blue and under layer setting they aren't locked or anything. I started this project in v14, never loaded or unloaded other libraries or anything. Any ideas?
3 Replies 3
Eduardo Rolon
Check the Object Lock Setting.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Are they MEP objects by any chance and you don't have MEP installed?
Thank you ejrolon! I feel really stupid for not figuring this one on my own... Why would AC lock these by himself? As long as it's solved.
Thanks again!
