AC20 Minor annoyances
Overall, I like AC20 a lot! However, there are a couple of minor issues that make it very difficult to work.
1) We seem to have lost the 3D line/flat color library previews, and so now all 3D previews are rendered. This makes it very hard to see any detail in a 3D view if the object is white on the white background. Is there any way to get the old-style preview back?
2) I've noticed that sometimes 3D elements like morphs do not show up right away in the 2D view if they were drawn in 3D. Sometimes it takes drawing a similar element in plan, and then all the elements show up. This is probably a bug, but is there any way to overcome this in the meantime?
Richard
AC26 (since AC6.0), Win10
60 REPLIES 60
David Maudlin
Jeff wrote:
the Find & Select box. So 'Add' is on the left and it pops up a box on the right, and then everything is collapsed.
On my Mac, the box pops up on the left side if there is enough screen space on that side, so try moving the palette to the right. Once sections are opened in the box, they remain open by default when the box is reopened.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Jeff Kogut
Thanks David, I moved things around on my screen to give room on the left and that helps.
AC19-23 | Win10 Pro | i7-8700K | Quadro P600 | 500gb 960 EVO M2 | Dual 28" 4k Samsung U28E590
Katalin Borszeki
Hi! We have been aware of this issue, there is an entry about this in our developer database (#212112). We are planning to add a WE checkbox under More Options to control the status of contours of the Favourite 3D previews and Library Part Settings 3D previews in the next ARCHICAD version.
Best, k
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
Stress Co_
What happened to the "Edit Selection Set" button,
which previously resided in the Layer Section of the "Info Box"??
I added it to my custom toolbar, but I'm so used to having it in that location.
Marc Corney, Architect
Red Canoe Architecture, P. A.
Eduardo Rolon
They removed it to make more space and because conceptually it shouldn't be there (don't get mad at me I am just the messenger ) If you use standard shortcuts, and the reason I don't miss the icon, it is CMD+OPT+T.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Stress Co_
As the title says, minor annoyance.
fuzzytnth3
Anyone else find opening the Favourites palette or clicking on the toolbar to pop out the palette slow?
I made a wee movie below showing how sluggish it is to appear.
https://dl.dropboxusercontent.com/u/399074/sites/trapdoor/SlowFavs.mov
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
Jeff Kogut
Yes, but no where near as slow as yours. With 10 favorites ours takes about 3 seconds to 'build' the list the first time the tool is used each day (why isn't this persistent and not need to rebuild each time the file is opened?). Subsequent openings are instant.
We are using SSD's on Core i7 with 16gb RAM. I'm guessing you have a spinning, maybe 5400rpm, drive which takes a while to spool up. Seriously, an SSD upgrade will make your system feel like a new computer.
Stress Co_
I'd call that one a Major annoyance.
That is a minor annoyance to me too
