2016-06-28
		07:26 PM
		2023-05-23
		04:18 PM
			Rubia Torres
2016-08-22 02:13 PM
Barry wrote:+01Stress wrote:The thing is the single click now gives us the option of pre-set angles and also the last user defined angles.
Quick Options Bar> Orientation
Much preferred the ability to reset to 0° with one click (AC19)
As opposed to opening a pulldown and scrolling to 0° (AC20)
I think this is a good option but maybe it could be made so a double click will reset to zero.
another Moderator
2016-08-22 02:38 PM
Barry wrote:I would like a similar behavior restored to the Zoom in the Quick Option Bar: double click to set Zoom to 100%. An alternative would be single click to set to 100% (AC19 and before), click and hold to get the pop-up list.Stress wrote:The thing is the single click now gives us the option of pre-set angles and also the last user defined angles.
2016-11-12 12:58 AM
2016-11-12 11:56 AM
2016-11-12 01:43 PM
Stress wrote:I am not seeing this issue. I don't know if still being on OSX10.10 is the difference.
If I select an object, line, wall, etc. and use keyboard shortcuts to "drag a copy" (or "drag multiply copies").
The + sign(s) pop up briefly, then disappear.
You have to move the cursor to get them to reappear.
In previous versions, they stay.
2016-11-12 06:49 PM
DGSketcher wrote:What kind of mouse are you using?
It's also annoying that duplicate mode clashes with using the ALT key to toggle pan/zoom
DGSketcher wrote:Does double clicking the "user origin" button in the coordinates bar palette bring it back? I've noticed this, but can't replicate it.
I also have an issue with the origin hiding when creating a new independent worksheets and details.
2016-11-12 08:08 PM
2016-11-14 02:49 AM
2016-11-15 06:51 PM
2016-11-15 10:27 PM
DennisG wrote:Dennis,
I used to be able to select and mirror text labels (you know, the ones with arrow leaders pointing at things in the 2D drawings). The text box would flip to the other side of the leader arrow, with proper justification.
Since upgrading to 20, the leaders have become "sticky" - I can no longer mirror a note so that the leader comes from the opposite side. The leader stubbornly remains on the original side, while the note justification changes.
I've also had problems with the leader being glued to an object, so that if the object is moved, the note moves too - which is not always desired.
Is there a way to dial back the stickiness of the note/leader?
Thanks in advance, pardon the outdated signature.
