AC20 Wall Accessories bug
Hi, i'im trying to work with bimobject's PLADUR & KNAUF wall accessories in AC20. but i can't switch between their different's models..
I installed the latest version of the goodies..
Thanks for your help
5 REPLIES 5
This is the screenshot for the knauf dialog box
Hi, did you talk to Bimobject? sometimes the libraries can have problems.
Hi All,
This looks strange.
I check the objects today and I will report you, what I found.
Gábor
BIMobject GDL developer Team
Hi All,
I tested the objects and I realised, Graphisoft no more allows to use some GDL commands in AC20 as it was accepted it before.
Because of this new rules, we have to check and update some of our contents and make some actions.
It takes time, but I will take care, that the Pladur and Knauf Danogips versions would be on the portal as soon as possible. I will also inform you here, if you can download the new versions from our portal.
cheers:
Gábor
Dear All,
I updated the Knauf Danogips solution on the BIMobject portal.
If you download the new version, it will works fine in Archicad 20 as well.
Thank you for your report.
Please, if you find any other problems regarding the contents, which you downloaded from the BIMobject.com report it also to us by e-mail to: support@bimobject.com
We are on it to maintain our solutions for your satisfaction... 😉
cheers:
Gábor
