sinceV6
AC21 Stairs - Will it go over itself?
Hi.
Playing a bit with the new toys, I noticed that -I assume it is by design- the stair tool won't go over itself. Is this true? I understand that in order to avoid potential problems with height clearance this could've been incorporated as a feature, or so that you can't make one single stair to build a 10 story staircase, but there are times when you have enough height between stories that you can bend the stair path to go over where it began, or a double full turn stair for a high lobby.
"Make two stairs", you might say... but how about a 1.5 turn spiral stair?
If this is how it is supposed to work, I think they revited the stair tool functionality.
Just checking things here.
Best regards.
10 Replies 10
Kamelite
The almighty Eric Bobrow has a tutorial on the subject!
https://www.youtube.com/watch?v=IRttsLcWtD8
.Kamelite
Windows 10, Archicad 27,28 and 29
