2020-06-18
05:12 PM
2023-05-25
04:38 PM
Rubia Torres
Solved! Go to Solution.
2020-06-18 09:30 PM
2020-06-18 05:24 PM
2020-06-18 09:30 PM
2020-06-18 10:50 PM
LaszloNagy wrote:Ah. Thanks Lazlo! Yes it's invalid but I had no idea the purple colour indicated that. Is it for stairs only?
This color usually indicates invalid geometry based on the settings and parameters.
Here is an example: You set the minimum Riser Height for the Stair to 150 mm. Your Story Height is 3000 mm and the Stair is set to be Toplinked to the Story above the Home Story. You create a Stair with 20 steps, so Riser Height becomes 150 mm, the minimum value.
Now, you go to the Story Settings Dialog and decrease the Story Height to 2800 mm. Since the Stair is Toplinked to the Story Height, the total height of the Stair should become 2800 mm, which means Riser Height should change to 140 mm, which is not possible since you specified that the minimum Riser Height is 150 mm. Thus the Stair cannot be generated, so it has invalid geometry and is displayed with this surface color.
2020-06-19 03:29 AM
2020-06-19 04:12 AM
