amgam
AC25 - 3D documents - disappearing colours and textures
My 3D documents look OK for a moment, then turn black and white, with no colors. Any ideas?
Here's the 2D document after the "bug"- it's black and white (had colors for a moment)
3D drawing after it went black & white3D drawing after it went black & white
Here's the 3D window (axo from which the 3D document was created) for comparison: the materials used have textures and colors. 3D window (showing colors)3D window (showing colors)
the settings I use for 3D documents: 3D document settings3D document settings
Is there a new feature in AC25 I don't know about maybe?
ArchiCAD 25 FRA 3011 + TwinMotion 2021.1.4
iMac Retina 27 2020 3,8 GHz Intel Core i7 8 cœurs
64 Go 2667 MHz DDR4
AMD Radeon Pro 5700 XT 16 Go
3 Replies 3
Gordana Radonic
Community Manager
Community Manager
Hi @amgam
did you check if you have any Graphic Override applied?
Gordana Radonić
Community Manager
amgam
I checked, but no other than all the elements around the stairs with railing as invisible.
It came back to "normal" for now. On it's own (just like it disappeared). I have to assume this is a bug.
64 Go 2667 MHz DDR4
Gordana Radonic
Community Manager
Community Manager
Hey @amgam
Good to hear it's gone. But if it repeats and you suspect it's a buggy behaviour rather than being caused with settings, you can share it with your Graphisoft support in charge.
Gordana Radonić
Community Manager
