AC26 macOS Magic Mouse instability
DGSketcher
Legend
Anyone else noticing instability and their mouse stalling? I am finding times when I can only pan and the mouse won't respond to the ALT change to zoom mode. There are other times when it seems like the mouse has lost focus with current window and it requires a click just to wake up the selection function.
12 REPLIES 12
Eduardo Rolon
What I am seeing is that the cursor gets stuck in an option like Pipette and it wont return to the pick arrow.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Yes, I am seeing that as well.
Lee Hankins
I am seeing that too, It happened during Beta and I did report it. If you click whichever modifier key the cursor is stuck in, it normally clears it.
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
Romans
I can confirm that behavior too.
After zooming the mouse keeps sticking in the Pan-mode.....
And the zoom is not happening to the place where the cursor is.
Apple iMac Pro with macOS Sonoma, AC 5.0 to 27 INT and GER, all the latest
I wonder if this is a Monterey issue?  I still haven't upgraded from Big Sur.  I'm not seeing any issues with my Magic Mouse on 11.6.7
DGSketcher
Legend
AC25 mouse activity is ok on Monterey, this is a new intrusive problem in 26, no doubt due to restructuring of the code and insufficient real world experience testing as usual.
Lee Hankins
I’ve managed to get in to the bug reporting system and have asked for an update of when this will be fixed. It’s definitely only affecting AC26, 25 is still fine. I’m running Monterey so I’m not sure if it could also be linked to that. Maybe someone running Big Sur could have a look.
Lee Hankins
macOS Tahoe (26.0)
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Thank you for the report and I am very sorry to hear about the issue!
I borrowed a Magic Mouse and connect it to a Macbook Air having M1 chip. AC26 3001 on Monterey has no problem with zoom/pan operations and the hotkeys respond without any delay. I'm wondering if there is a stable method to reproduce the issue?
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
DGSketcher
Legend
@Minh Nguyen I don't think this is one that typical end users will pin down. I have a growing feeling that there are a number of disconnects happening in AC26 - 3010 UKI (macOS) where there is a loss of focus on user input, for instance I had to exit 26 this morning because I spent some time in safari and went back to find the navigator search field wouldn't accept text. I'm pretty sure these mouse input problems are a coding issue that needs some concentrated stress testing at GSHQ using a decent size model to flag up any data delays which may possibly reveal multi core processing not syncing up their results or even something more fundamental.
