Rita Diniz
AC28 and Library Part Maker (LPM)
When will it be possible to make arched windows and doors using the LPM add-on provided by graphisoft?
It doesn't seem to have been solved in this version, at least I couldn't get the hole in the wall to match the window/door.
An add-on with huge potential, but which, once again, fails to realise its full potential - frustrating.
Operating system used: Mac Intel-based 12.7.6
4 Replies 4
cuba
Did you add a slab with a 'Wallhole" as element id? You need to do this to make the correct opening in the wall.
Apple M1 Max 32 GB
Latest AC
Rita Diniz
Yes. That workflow, for me, only works if you save it as an object (window or door). Not using LPM.
cuba
Unfortunately, the workflow with the wallhole does not work in the lpm. I tried adjusting the wallhole in gdl but this is very difficult to align correctly.
Apple M1 Max 32 GB
Latest AC
