‎2025-04-09 11:38 AM
When will it be possible to make arched windows and doors using the LPM add-on provided by graphisoft?
It doesn't seem to have been solved in this version, at least I couldn't get the hole in the wall to match the window/door.
An add-on with huge potential, but which, once again, fails to realise its full potential - frustrating.
Operating system used: Mac Intel-based 12.7.6
‎2025-04-09 11:47 AM
Did you add a slab with a 'Wallhole" as element id? You need to do this to make the correct opening in the wall.
‎2025-04-09 11:48 AM
Yes. That workflow, for me, only works if you save it as an object (window or door). Not using LPM.
‎2025-04-10 10:52 AM
Unfortunately, the workflow with the wallhole does not work in the lpm. I tried adjusting the wallhole in gdl but this is very difficult to align correctly.
‎2025-04-11 09:41 AM
Hi Rita 😉
I'm with you on this one: https://community.graphisoft.com/t5/Wishlist/Library-Part-Maker-Improved-Handling-of-Non-Rectangular...
