2004-10-25
06:44 AM
- last edited on
2025-01-30
11:46 AM
by
Molinda Prey
2004-10-25 06:51 AM
2004-10-26 04:40 PM
2004-10-26 08:26 PM
2004-10-26 11:03 PM
2004-10-27 03:35 PM
In some cases it was my fault because the fills in my new template, built by pasting in choice fills from other files, had non-consecutive ID numbersThis is a bit off topic but how can you adjust the ID numbers of fills?
2004-10-27 10:36 PM
Mike wrote:Make sure you have a file, other than the one you want to fix, that has all the fills you need. This can just be a copy or an .aat exported with Attribute Manager (AM). Save a back-up of the offending file, then open AM and delete all the fills. You’ll be left with one, hopefully number one. Open the other file in AM, select all the fills save number one and Append. They will order themselves consecutively. Check the list as I’ve had the process skip a couple for unknown reasons. You can do the same with Lines and Materials. If the left-behind fill is not number one you may need to append in two groups. You can always cancel out of AM and try again if it doesn’t go well. Once you have a clean set save a copy of this file to use when fixing other offenders and to build a new, clean template.
