ā2004-09-02 05:40 PM
ā2004-09-02 09:37 PM
ā2004-09-02 09:42 PM
tprokop wrote:No layering, you can control the display, and visibility a storey up, down, or on a storey
1) Will the slab fills work like Slabhatcher with the layering or is the display option their only toggle?
tprokop wrote:I still prefer ArchiForma
2) Are there any improvements to the profiler or must we still sit in awe remembering the presentation at ACUW?
tprokop wrote:Lower than comfortable ... but then, I go to sites at 47C in the shade (shade?) and with RH over 85% so ...
And just because I'm curious, refereing to another thread -
3) What is the average temperature in Alaska in May?
ā2004-09-02 10:13 PM
ā2004-09-03 12:18 AM
ā2004-09-03 01:46 AM
ā2004-09-03 05:23 AM
ā2004-09-03 05:39 AM
ā2004-09-03 03:27 PM
tprokop wrote:Yes, they can.
Another question:
Can the origins be set on the slab fills?
ā2004-09-03 04:35 PM
MSotero wrote:The new text editor does not support multiple columns. However tabulators and indents are available and copying/pasting from MSWord works also fine as a result of it. The attached picture shows a text copied from Word and pasted into one textblock on the floorplan.
1) Does the new text editor (word processor) handle multi-column text directly or by import from Word? So we might be able to do sheet specs and other extensive documentation?
MSotero wrote:I do not really see what you exactly mean. Although I can say, that there are no associative links between text blocks and the grid.
2) Can the PM grid system be used/adapted to handle flowing text and auto generate the next sheets?
MSotero wrote:There has been no improvement made especially in these areas, however with the introduction of cover fills there are some more display options to finetune how the cut fills/cover fills/drafting fills are shown allowing easier methods for example to make sure how different AC elements are shown in different views.
3) Given the work flow improvements, has there been any attempt at providing a truly integrated working method of handling typical base sheets for mechanical, electrical, structural, etc drawings?
