ACAD 15 - Cut Fill on Plan - Origin
How does one cotrol the origin of the cut fill as displayed on Plan? I want to be able to show individual bricks on plan. See attached:
Any suggestions welcome.
4 Replies 4
Erika Epstein
Zak,
Your link isn't working. Alternatively you can add a screen shot as an attachment to your post, see the bottom of the page.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
[Sorry Erika/Zak- that was my fault. Zak double-posted but did originally post the screenshot properly, and I deleted the duplicate... but that apparently deleted the shared screenshot.... Karl/Moderator-hat-on]
Thanks... fixed it. Any genius answer yet?
Hi... As I'm not a master in archicad ... I'm not sure its the best way or not ! but you can make a detail or worksheet of your section which you draw and then select the cut fill , change the " construction method " in Fill selection Setting From " Relative to the project Origin " to " relative to the fill origin " then change the Origin Of your fill brick.
hamedkassaei
