ARCHICAD 19 Update 4011 Is Available
AndorSzoke
Graphisoft Alumni
Graphisoft Alumni
We have released ArchiCAD 19 Update 4011. Besides several improvements this Update makes ARCHICAD 19 compatible with MAC OS X 10.11 (El Capitan). It is currently available through the automatic update system for the INT, USA, UKI, NZE language versions. GER and AUT versions will be released tomorrow. Further language versions will be enabled as they pass Quality Control. You can download the Update packages from the Release Notes page here:
http://www.graphisoft.com/downloads/archicad/updates/AC19/AC19-3003to4011-ReleaseNotes.html
AndorSzőke
Product Management
GRAPHISOFT SE
Follow us on Twitter
GRAPHISOFT HelpCenter - the ArchiCAD knowledge base
40 REPLIES 40
Karl Barker
As we have not yet implemented AC19 as yet, is there a link to download a full up to date build number installer? Or do I need to use the previous build installer and apply the hotfix after?
Karl Barker.
27" iMac 3.6 Ghz Intel Core i9
32 Gig Ram
Mac OSX 10.14.6
AC 5.5 - AC22 (NZE)
You need the initial installer and then apply the latest hotfix.
I am not sure that the original installation files ever get updated.
svpribyl
From the HELP menu with ArchiCAD running, I selected "check for updates". My version is not up-to-date per the website. I downloaded and tried to install the update, but the updater says I don't have a version of ArchiCAD that can be updated. I also tried browsing for the ArchiCAD app, but that didn't work either.
UPDATE:
I tried it again today and the update installed properly.
Steve Pribyl
MAC OS Sonoma 14.5
ArchiCAD 28
PB
Thanks AndorSzoke - that's great news !
AC27 Apple Silicon. Twinmotion.
16" M1 Max MacBook Pro 32GB, Apple Studio Display, MacOS 15
Yes! Really good news. I hope it fixes the things I was hoping for.
We have had some really inconsistent results with this Archicad 19 - 4011 update, in one of our other offices it rendered ACD19 unusable... Mine still works, but I get this error message when starting. Any help, because I have no idea what it is referring to?
That error is caused by Cadimage Tools. See their blog:
http://blog.cadimage.com/2015/10/archicad-cannot-start-because-modules-are-incompatible/
You can still use Archicad 19 without any issues.
Build Number may not be showing correctly everywhere ?
when the update will be launched in Spanish?
