We value your input! Please participate in Archicad 28 Home Screen and Tooltips/Quick Tutorials survey
2015-10-26 05:16 PM
2015-11-02 06:20 AM
2015-11-02 08:12 AM
2015-11-02 08:39 AM
2015-11-02 12:18 PM
2015-11-02 02:16 PM
2015-11-02 02:57 PM
Erwin wrote:The Hotfixes usually apply to all language versions. You use the update to check against your language version. But the Hotfix refuses to work on the INT installation folder, whereas it works on the NED installation folder.
Stefan,
I generally install updates by using the Help > Check for updates... button. This allways sends me to the right download.
Could it be that your NED version is trying to update the INT version?
2015-11-02 03:11 PM
2015-11-03 10:12 AM
Erwin wrote:Seemed good thinking, but I'm pointed to exactly the same download. I never heard of language specific hot fixes, although the NED version usually tends to take a while before a hot fix is seen when INT is already available.
I think it actually is a NED only version (the update).
Try checking for updates from your INT version and downloading and installing from the page that sends you to. It might work then.
2015-11-03 09:24 PM
2015-11-04 02:05 AM
