2017-09-26 04:52 PM
2017-09-26 05:12 PM
2017-09-26 06:34 PM
2017-09-26 07:16 PM
dkovacs wrote:It seems that the required HDPI cursor scaling registry key is not actually present by default - perhaps that is why the update 4004 was not sustaining any increases in cursor size?
Hello Paul King,
I have posted the solution for your problem in the original thread about this issue.
In most cases installing the update should solve the issue, but sometimes (like in case of Paul King) this fix won't change a thing. In these cases you will have to manually set the cursor size from the Registry. You can find a full description of this issue and the solution in this Article:
http://helpcenter.graphisoft.com/?p=74887
Good Luck!
2017-09-27 02:54 AM
Paul wrote:dkovacs wrote:It seems that the required HDPI cursor scaling registry key is not actually present by default - perhaps that is why the update 4004 was not sustaining any increases in cursor size?
Hello Paul King,
Good Luck!
2017-09-27 08:10 PM
2017-10-02 01:27 PM
daninet wrote:We plan to include this solution in the next update for ARCHICAD 20 as well (due to be released until the end of this year).
we need the same hdpi fix for 20 so bad... registry hack not working for me
2017-10-04 04:02 AM
dkovacs wrote:Just confirming that neither update 4022 nor the registry hack have permanently solved the small mouse pointer problem. For while the registry hack worked for preview patch 4004, but eventually (for reasons unknown - but apparently NOT due to any further windows update) it stopped working. The registry entry is still there unchanged from when it was working.
Hello Paul King,
Good Luck!
2017-10-05 05:10 PM
2017-10-06 03:13 AM
januszg wrote:If you use the latest updated version of the CADimage Title #1590, this problem goes away . Apparently issue is caused by ArchiCAD no longer supporting 'old school' AutoText
Layouts with multi drawings with autotext titles saved to PDF show all drawings names together. Attached PDF drawing. Error exist in Windows and Mac OS
