ARCHICAD 22 INT version now available for download
It can now be downloaded from the following web page:
http://www.graphisoft.com/downloads/
Other localized versions will be coming soon.
23 Replies 23
We´re eagerly waiting for the v22.1 (4005) GERMAN version — with first error corrections.
________________________________________________________________
[list=]
  • Besides waiting — what exactly is the difference between GER and INT versions?
  • If we install the INT version, what has to be done to run the GER version, when it´s available?
  • Laszlo Nagy
    I think the INT and GER versions are different in many areas as defined in their Template Files: Library, many Attributes, View Sets, Publisher Sets, etc. There are also certain commands and functions that are specific to German-speaking countries, which are included in the GER version.
    You just need to install the GER version in another folder so you will be able to run one or the either, or both at the same time.
    However, if you don't have a GER license you may or may not be able to run the GER versions, I am not sure about that.
    So WHEN will the GER version probably arrive?
    Thanks.
