ARCHICAD 23 Update 4004 INT AUS NZE UKI and USA Preview version available
ARCHICAD 23 INT Update 4004 Preview version is now available. Please note that it IS a Preview Version so to quote GRAPHISOFT:
This is a “Preview” Update available for the members of the ARCHICAD community to test in advance of the Public release of the final Update. Based on the feedback from users this Preview will either become the final release or another Final Update package may be created in case any issues are found in this Preview.
WARNING: Proceed at your own risk! Do not install Preview Updates into your mainstream workflow without being able to roll back your server and client machines to the previous Update.
It can be downloaded from here:
https://www.graphisoft.com/downloads/archicad/updates/?type=FULL&version=23&localization=INT
5 Replies 5
I've updated the subject line of this announcement to reflect the 5 localized versions that were made available as of 6 Feb 2020 - still just those 5 today.
As a side note for Mac users - Safari will not display the drop-downs / downloads for me today (worked last week) - but Chrome works fine.
https://www.graphisoft.com/downloads/archicad/updates/?type=FULL&version=23&localization=%E2%80%93
Minh Nguyen
Hi Karl,
Thank you for your report!
We checked it with Safari and the drop-down menus are working fine. Could you give it a check again to see if it's still an issue with Safari on your computer?
Thank you very much!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Hi Minh,
Works fine in Safari today. Thanks for checking.
(Strange that I've seen no user discussion of this 4004 update as we have seen here for all prior preview updates (to 22 etc). Typically, I would expect some of the people posting in the 'problems with 23' thread to have posted that this 4004 build does or does not fix their issue.)
DGSketcher
Legend
Still reporting problems Karl and getting the usual mix of :
- We're working on it, not sure when it will be fixed though.
- It's low priority as not enough people have complained.
- It's historic but the good news is there is a wish for a fix.
If it's a war of attrition, I'm not sure the user is winning.
Very disappointing to hear. 😞
