2004-02-29 11:16 PM
2004-03-01 05:59 PM
lsid wrote:Find the similar True Type font, and assign it in the translation font table. If you wsnt to translate SHXs to TTFs, you have to have both of the same name. All the standard SHXs have corresponding TTFs provided by Autodesk, when you install AutoCAD. So the person you got the drawing from might have the TTF?
Is there anyone there able to help me get this font ARCHITXT fonts as shown in the pic here for Archicad. I have it in Autocad but it is in SHX format and can't use it for Archicad.
ac7/xp
2004-03-04 03:32 PM
2004-03-05 01:48 AM
2004-03-08 06:56 PM
2004-03-15 06:30 PM
2005-02-10 05:59 AM
LewBishop wrote:just purchased them but cannot for the life of me get them to install - the system just won't recognise them for what they are - fonts. i've tried adding the extension '.ttf' to the end. the system then thinks that they're fonts, but still can't use them.
A good substitute is a font pack available from Objects On Line called " Architects Font Pak" and has a font called MrHand and Heavy Hand that work really well and look good.
2005-02-10 04:03 PM
just purchased them but cannot for the life of me get them to installGidday Ben:
2005-02-11 12:45 AM
Stress wrote:yeah - i tried that too: no luck. font book wouldn't recognise the files.
What I needed to do was launch "Font Book" (in applications folder?) and from the menu bar: File> Add Fonts....
 ), so if anybody else comes here with a similar problem that's what you need to do . . .
