ASCii-code in Textbox
Is there a simple way to put ASCii in AC9. In AC7 you could press "ALT + number" but this doesn't work in AC9. And the "Insert Symbol" function takes to much time to use.
Anyone who has a solution?
/Tobias
4 Replies 4
Greg Kmethy
Graphisoft Alumni
Graphisoft Alumni
This seems to be a bug. Unfortunately you probably can't help it.
Greg
Gergely Kmethy
VP, Customer Success, Graphisoft
Mats_Knutsson
Mentor
/Tobias
I got the solution from Turboglider who originally posted the question. He forgot his login so I post it instead.
[Ctrl]+[Alt]+ascii code will do the trick.
/Turboglider via Mats
AC 25 SWE Full
I find that you have to conciously press CTRL before ALT or it doesn't work (if you press in opposite order)
Mats_Knutsson
Mentor
Never tried that one....😉
The problem is probably gone in AC10 anyway.
/M
AC 25 SWE Full
