Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. Learn more…
AUTOTEXT LABEL MESH ELEVATION NODES SELECTED IN A 3D DOCUMENT WINDOW
Labeling node elevations in plan view works nicely using the level dimension tool and gravitate to mesh on. Is it possible to do something similar in the 3D Document window?
Tks!.
Zin.
1 REPLY 1
It is possible to create a view showing the level dimensions and then add it in the layout above the "3D document" view
So dimensions + "3D document" (from a level plan) is possible and dynamic of course !
Like this (poor job but the aim is here) :
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
