2008-02-19
06:25 AM
2023-05-25
05:53 PM
Rubia Torres
2008-02-19 06:59 AM
rm wrote:It's still the same as it was before but now there are more choices of what stories you want to see it on. You can even show outlines and coverfills on different stories.
In the world of hand drafted drawings, if one was drawing something above your home story/floor, you would draw it with a dashed line. The same element when viewed from above would be drawn with a solid line.
This is pretty much how it worked in AC 9 , maybe AC 10 too....and it worked pretty well.
Then Graphisoft thought to change how this works....like changing all the menu locations, this was a bad idea.
For example, first story is 10' high. I want to draw a ceiling 2' thick with a slab above. Normally I would go up to the second story, draw the slab there. From the second story the slab is viewed with a solid line at the perimeter. As a portion of it extends horizontally past an exterior wall forming a ledge, when viewed from below, that same slab perimeter should show up as a dashed line when on the first storey....as it did in AC 9 ( and I believe in 10 as well )
Then comes AC 11. If I draw that slab on story 2, no matter what multitude of settings I choose I cannot get it to show up on story 1 as a dashed line at the perimeter. If I try to cut and past that same slab from the second floor down to the first floor, it dissapears, as it is higher than the limits of the first floor.....who thought this change was a good idea??? t
I suspect AC 11 can do what I am asking for, but again, it must be barried so deep in menus I can't seem to make it work. BTW, I have used AC for 14 years, so I am not new to this. The AC 11 interface has really messed me up.....and I suspect other legacy users as well.
Hope someone can explain how to make this work.
Thank you!
2008-02-19 10:34 AM
rm wrote:Sometimes old users like me need to take a crash course on how to efficiently utilize the features of new versions...
2008-02-19 06:00 PM
