harryparso
Accidentally closed where you access modelling tools (toolbox)
hi all im new to archicad and have an assignment due soon and have somehow closed where I would access things like walls, objects, stairs etc im on mac can anyone plz help me out @eer in the attached image on the left hand side of the photo there used to be a tab bar where I could select the walls etc now its gone and i cant get it back and apoglies if I have posted this in the wrong place im stressing right now lol
2 Solutions
Rubia Torres
Hi @harryparso ,
You can bring back the Toolbox through the "Window" menu:
Best of luck with your assignments and learning journey!
Rubia Torres
Community Expert | GRAPHISOFT SE
Did you get a helpful answer on the forum?
Give it back to the Community by marking it as an accepted solution!
Go to post
aarkell
That's part of your work environment. You can go to Options>Work Environment>Apply Profile to get back the one you were using. Alternatively, you should be able to access the palette via the Window>Palettes>Toolbox.
Andrew Arkell
AC 18-27 USA 5030
HP Z6 G4 Workstation | Intel(R) Xeon(R) Gold 6226R CPU @ 2.90GHz | Windows 11
Go to post
3 Replies 3
aarkell
Andrew Arkell
AC 18-27 USA 5030
Rubia Torres
Hi @harryparso ,
Rubia Torres
harryparso
thank you so much saved my life @Rubia Torres
