harryparso
Accidentally closed where you access modelling tools (toolbox)
hi all im new to archicad and have an assignment due soon and have somehow closed where I would access things like walls, objects, stairs etc im on mac can anyone plz help me out @eer in the attached image on the left hand side of the photo there used to be a tab bar where I could select the walls etc now its gone and i cant get it back and apoglies if I have posted this in the wrong place im stressing right now lol
2 Solutions
Rubia Torres
Hi @harryparso ,
You can bring back the Toolbox through the "Window" menu:
Best of luck with your assignments and learning journey!
Rubia Torres
Community Expert | GRAPHISOFT SE
Need help refining your Archicad skills?
Check our Modeling knowledge base for the best workflow + tips&tricks!
Go to post
aarkell
That's part of your work environment. You can go to Options>Work Environment>Apply Profile to get back the one you were using. Alternatively, you should be able to access the palette via the Window>Palettes>Toolbox.
Andrew Arkell
AC 18-27 USA 5030
HP Z6 G4 Workstation | Intel(R) Xeon(R) Gold 6226R CPU @ 2.90GHz | Windows 11
Go to post
3 Replies 3
aarkell
Andrew Arkell
AC 18-27 USA 5030
Rubia Torres
Hi @harryparso ,
Rubia Torres
harryparso
thank you so much saved my life @Rubia Torres
