SOLVED!
Align Ci-wall Cladding
asipasy
Hi everyone,
Does anyone know how I could align the Ci tool wall cladding on each other?
My design related to the alignment of each floor's wall cladding on top of each other.
Thank you so much for your help in advance.
1 ACCEPTED SOLUTION
Solution
Use a curtain wall instead...... Far more detailed and adjustable than an object like CI coverings.
3 REPLIES 3
Please contact Central Innovation for support on any Cadimage tool as they are the developers, not Graphisoft 🙂
https://centralinnovation.com/archicad/ci-tools/#
(With luck, someone here may know the answer while you wait for Central Innovation support to respond to your email.)
AC 29 USA and earlier   •   hardware key   •   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
asipasy
Thank you so much, Karl.
Solution
