2007-05-30
03:48 AM
- last edited on
2023-05-23
03:18 PM
by
Rubia Torres
2007-05-30 04:12 AM
2007-05-30 04:51 AM
2007-05-30 05:01 AM
2007-05-30 05:14 AM
Dwight wrote:I can tell you're an old timer. Used to be that way.
To edit the roof you must be in the roof tool with the roof selected, otherwise you will drag the entire roof.
2007-05-30 05:21 AM
2007-05-30 05:34 AM
2007-05-30 08:50 AM
camhabib wrote:So it was grouped? That was going to be my next guess. Hard to answer the rest of your question because I'm not sure exactly what you are trying to do. The general answer is yes there are very quick and precise methods for editing roofs.
ETA: I selected the "suspend groups" option allowing me to edit the points, however, I'm having a little trouble reconfiguring the lower right side of the section. Is there any easier and more precise way of reconfiguring the roof other then just kind of guessing and checking with the points?
2007-05-30 06:11 PM
Matthew wrote:Actually strictly speaking thats not true either (maybe another old timers habit?) you can have both roofs selected and click the edges of each in turn. Makes for a simple way of meeting roofs..
if you select one (and only one) roof, you can command/ctrl click the edge of another
2007-05-30 06:40 PM
