Angled Sections???
Hi
I'm sure that this can't be done at the moment but we'd like to be able to generate sections from angled section lines. So, for example, a section line starts runs for 10 metres then turns 35 degrees then runs for 5 metres then turns 15 degrees etc etc.
Anyone know a way???
If not then GS please add this to the wish list...
Adri
4 REPLIES 4
You can't do this, but you can fake it manually ofcause. Make all parts as own sections and then put it all together with copy'n'paste.
Thomas Holm
Or save views and join them on a Layout.
You can use in AC11 the new "internal sections" tool in linear mode (?) (I'm not sure of the name because I'm using a french version) see the images attached. It's tricky but easier than setting multiple different sections…
Thomas Holm
Does it work with all angles? Both positive and negative?
