Need help with Roof Plan
I am working on a building with multiple units. Each unit has roof planes that interset eachother. I do not know how to make it look correct on the roof plan because roof coverfills and display order are not user friendly. There must be a simple way to do this without going in and placing individual coverfills where lines should not show? I have played with the different settings in the roof tool (projected, outlines only) they don't seam to help.
8 Replies 8
Thomas Holm
Read the Help file on the Trim and Trim to Roof commands
The roofs are trimed correctly, I am having trouble with overhangs that should not being showing through the roofs above.
Djordje
Can you post a screen shot? Then it will be clearer.
Generally, the higher roofs should have a cover fill with opaque background. And they should NOT all be at the same storey - lower have their own, higher have their own. Then you can play around ...
Don't forget the plan cutplanes and other candy for guzzling downers 😉
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
I don't know how to take screenshots in enemy territory(PC Land) but I am going to just use fills to cover what I don't want for now. This project is tricky because there are many overlapping roofs that are only a matter of inches above each other. Therefore they are all on the same story
eastcoast413 wrote:
I don't know how to take screenshots in enemy territory(PC Land) ...
Hit the PrntScrn button, then paste into an image editor.
David Maudlin
eastcoast413:
For what it is worth, I have generally been able to get the roofs to display correctly using cover fills and the display order. If you can, set the uppermost roof to the top of the display order, the lowest to the bottom, then select individual roofs and use the keyboard shortcuts to move up and down in the display order, which, if I remember correctly, has 13 places in the stack. The only time I have to resort to 2D fixes is when one roof starts above another, but then passes it by and part of it ends up under the second roof.
HTH
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David wrote:
eastcoast413:
HTH
David
Yes that is what is happening in all of the roofs, 2D Cover fills have worked to fix it. Also I have been having trouble with the display order. Sometimes where I choose bring to front for an element it always works no matter how many of the other elements below have been brought to front in the history of mt work day. Though Sometimes bring to front just does not work???
-thanks, good to know
