2007-11-27
05:38 PM
2023-05-23
03:14 PM
Rubia Torres
2007-11-27 05:41 PM
2007-11-27 06:25 PM
2007-11-27 06:31 PM
2007-11-27 08:31 PM
2007-11-27 08:39 PM
eastcoast413 wrote:Hit the PrntScrn button, then paste into an image editor.
I don't know how to take screenshots in enemy territory(PC Land) ...
2007-11-28 02:52 PM
2007-12-05 05:03 PM
David wrote:
eastcoast413:
For what it is worth, I have generally been able to get the roofs to display correctly using cover fills and the display order. If you can, set the uppermost roof to the top of the display order, the lowest to the bottom, then select individual roofs and use the keyboard shortcuts to move up and down in the display order, which, if I remember correctly, has 13 places in the stack. The only time I have to resort to 2D fixes is when one roof starts above another, but then passes it by and part of it ends up under the second roof.
HTH
2007-12-05 05:09 PM
s2art wrote:-thanks, good to knoweastcoast413 wrote:Hit the PrntScrn button, then paste into an image editor.
