Font Import
Could anyone tell me if it's possible to import a font type in .ttf format into archicad for us to use?
thanks in advance
Joel
3 Replies 3
Eduardo Rolon
That is a function of the OS. In Mac use Font Book in Windows XP is under control panel -> fonts. Once installed it should be available for AC though it sometimes the software needs a restart.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
If a font in Home/Library/Fonts isn't showing up in AC, try moving it to HD/Library/Fonts or vice-versa. I've seen AC act picky about this, and sometimes one works, sometimes the other.
James Murray
That worked perfectly.
Thanks very much for your help
Joel
