‎2013-01-23
06:16 PM
‎2023-05-23
02:38 PM
Rubia Torres
‎2013-01-23 10:52 PM
‎2013-01-23 11:17 PM
‎2013-01-24 06:24 AM
‎2013-01-24 06:27 AM
‎2013-01-24 12:23 PM
jballar wrote:Indeed, this is one solution. But in real life you can't make a beam thinner just because Archicad doesn't intersect well the beams.
The way I fix it is to make the beam thinner.
Jeff
‎2013-01-24 12:25 PM
MrC wrote:I think this is the only solution, but as you know in design phase you need to change the angle or else ten times per hour and to make one SEO let's say per day but it's time consuming.
ROOF SET TO ZERO THICKNESS AND AT THE APPROPRIATE BISECTION ANGLE AS OPERATOR IN SEO'S
‎2013-01-24 06:11 PM
‎2013-01-25 07:43 PM
‎2013-01-27 02:16 AM
