Angled wall base
Hello, I am trying to model a wall with an angled bottom base to it. In other words, if you were looking at the wall in elevation, the bottom of it would not be flat. Is there a way to achieve this? Thanks
The best way will probably be to use a Solid Element Operation with the wall as your target and a roof (at the slope and position you want) as the operator.
Then "Subtract with downwards extrusion".
You can hide the roof in a layer that can be turned off.
Don't delete it as the SEO is a live operation so delete the roof and the trim is deleted as well.
On the plus side you can move and adjust your roof to adjust the trim.
David Maudlin
DuncanB:
Another option is to create a Complex Profile Wall; in the Help files see: Virtual Building > Construction Elements > Place a Wall/Column/Beam with a Complex Profile > Creating or Editing a Complex Profile Element.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks for your help. Just what I needed to get the job done.
